Discuss Ceiling wiring got me worried in the UK Electrical Forum area at ElectriciansForums.net
careful buzz, don't give away the secrets of your retro rockets.
As I can hack users comps with impunity I have found out that Buzz is working on an "upgrade"
Looks like 2 neutrals 3 in loop and 1 switch live. If you find out which is which loop in connector and neutrals Earths and switch live connect to light
It would have been wise to note where each wire was connected before disconnecting. Maybe even mark them up with a sharpie.
Also, it doesn't seem a good idea to come on to a forum full of electricians and basically say 'I don't want to pay you to do this job, so can you give me some free advice'.
I don't want to pay for a regs book and have a day off work to take a regs exam and CSCS every couple of years but I have to (others on here have to pay to belong to a scheme).
1. Spend a little time researching wiring diagrams and electrical safety.
2. Trace where as much of the cables run to as possible.
3. Buy a voltage detector.
4. Use common sense and your new knowledge and tools to complete the task safely and sit back chuffed at your accomplishment wondering why you thought it was so hard in the first place.
There's a reason why it is considered perfectly safe and legal for a homeowner to carry out basic tasks like these with no need to notify the authorities or have it inspected.
yeah, but that's for home owners that realise that electricity can kill, is more complicated than plumbing....unlike shyte, electrickery don't run downhill, it runs down you.
I'm pretty sure anyone competent enough to register on and start a new thread on a forum will be sane enough to realise the dangers presented by mains electricity.
I dunno; think someone once said that Albert Einstein had so much intelligence, he could predict where an asteroid would strike the Earth, but wouldn't have the common sense to get out of the way. :)
Hi all,
I took down a kitchen light fitting and expected to fit the new one the same way - nope, nothing so easy eh? I am NOT an electrician but equally really don't want to pay the £100 to have someone come and do something I am sure I can do myself given a bit of advice.
The light fitting has just a L and N fitting so sorting out so many wires has got me puzzled. There is no ceiling rose either.
20190311_125202.jpg - https://drive.google.com/open?id=1X-v8eknbivtEBWl0YZRZmDobISkCAjB7
Thanks in advance for any advice you can give me.
Read up on Loop In and Loop Out.
Here's a thought for the Op. Once connected all back and working - is the job really done? Most DIYers think 'working' is enough and they are handy at electrics - but this is just a functional check. How do you know it'll stop working if there is a fault? This is the purpose of the testing, it confirms to the electrician that the circuit is within tolerance to operate the protective devices in place, it's physics not magic.
Light fittings again, diy's always dismantle then? So follow pete999 advice it's sound and excellent value. Hey magnoliafan89 dump the choc blocks and get some wago's the new way, you won't regret it.
I went to a house fire caused by an incompetent diy’er doing the same thing, just changing a kitchen light fitting. He connected all the Blacks together and all the Reds and turned it on. It didn’t blow the fuse as he had rewireable fuses wired in very heavy copper wire, this caused the cable to get very hot under the floorboards catching things alight. He learned a lesson, get the professionals in and pay the small fee.
Reply to Ceiling wiring got me worried in the UK Electrical Forum area at ElectriciansForums.net
Hi. Looking for some guidance please as I’m wanting to replace a ceiling rose fitting into a ceiling pendant. Done this many times but never come...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
