Aico 3000 Range
Discuss cheap 12V garden lights! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
aidge
Got called out to look at 12V 20W plug and play garden lights with MR16 lamps that are working at varying levels of brightness. Before i start taking everything apart anyone got any ideas on what would effect the lumin output of different lamps on the circuit or is it likely that its just down to a cheap set performing at different levels?
Test Meter - Forum Sponsors since 2007!
telectrix
Mentor
at a guess, poor connections to the fittings. either the pins on the lamps corroded, or, some are spiked onto the highway cable just by spiking through the insulation. these give terrible connections.
telectrix
Mentor
corrosion is always a huge problem when you get 12V and damp combined together. might think you've found a CuSO4 mine.
Wetroom Store - Network Wetroom Suppliers
Reply to cheap 12V garden lights! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
uHeat Banner - Forum Discount Available
Top Bottom
