- Reaction score
- 2,833
Good morning all. How would you code the following?:
1 - Electric shower installed without RCD protection, where manufacturer states it is required? Supplementary bonding present.
Normally I would give this a C3, but in this case the manufacturer states RCD required, so am erring towards C2.
2 - No RCD protection for socket outlets in 3rd floor flat that could be used for mobile equipment outdoors.
The flat has a very large, uncovered balcony, so it is likely that outdoors mobile equipment would indeed be powered by sockets in the flat, potentially in a wet environment. For sockets in the ground floor of a building I would C2 this. However, this being a 3rd floor flat, I question if the level of danger is the same. I would imagine that someone standing on the balcony, receiving a shock, would not be at the same risk as someone standing on the ground receiving a shock. Could this be a C3?
