Discuss Cooker circuit advice. in the UK Electrical Forum area at ElectriciansForums.net
currently doing a re wire waiting for the kitchen spec. Customer has planned for a halogen hob in an island which will get its own supply however he’s also after 2 single ovens stacked on top of each other on the opposite side of the room. It’s likely that both ovens will be on together so I plan to have them on their own circuit too. Just after advice on whether I should pull in it’s own ring or a 4mm radial. Or different
If In doubt then anticipate the worst case , pull in a couple 4 or 6mm radial feeders
I never use a ring circuit for cookers / ovens / hobs
Reply to Cooker circuit advice. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
I’m going to call an electrician out on Monday, but curious if anyone has any ideas about this fault: I have a new kitchen fitted and two...
