Discuss Cooker hood - connection but no current in the UK Electrical Forum area at ElectriciansForums.net
hi all,
i recently bought a flat and got a years old cooker hood in it.. which i am trying to replace..
all done but the connection inside it does not have power... tried all the switches on and stuff but still no joy..
any place where is should check .. or how to find the fault or where the connection may be ?
i have attached pics of the same.
so what voltage do you have across the brown and blue in that JB, and is that D/P switch the one for the hood?
If you have a grid switch arrangement in the kitchen with multiple switches for different appliances it could be there ?
Maybe. Or it may come from under the bathroom floor, above.?
If you can't find a switched isolator and supply source, get a spark in.
hi all,
Is it plugged in
' ypu may have a duff fuse in the plug top
I'm all for DIY bro but please get a spark in. It will probably take them 10 minutes to find the problem and less than an hour all in to sort it all out. You're looking at about £100 max.
I'd agree with this. No shame in needing an expert in.
Reply to Cooker hood - connection but no current in the UK Electrical Forum area at ElectriciansForums.net
Hi, can someone please advise on where if anywhere I may acquire an adapter to duct out this old Elica cooker hood. The hole is 150mm x 90mm and I...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
