BillMcLeod
- Reaction score
- 0
Hi. First post here.
Background
I have a relative who is an electrician and is about to re-wire our home as a favour. I said that I will order and pay for all of the parts - so that they are here in on-site when he arrives to begin work.
I have already ordered a Hager consumer unit; the 10 Hager RCBOs I need; 35mm steel knock out boxes; 300M of 2.5MM T&E cable; 300M of 1.5MM T&E cable; 100M of 1.5MM 3 core&earth cable; some 10mm cable for the electric shower; and a load of Hager faceplates.
The part that I am struggling with slightly is the correct set of light switches for the bedrooms and for the hall. Most of the light switches are simple 1, 2 or 3 gang 1-way switches. In the bedrooms however, I will need 2-way switches and intermediates, but I can't quite get my head around the right ones to order - so I'm hoping someone can help me out...
My Question
In each of the bedrooms, there will be: 2 ceiling pendant lights; a bedside 5A lamp socket at the left of the bed; and a bedside 5A lamp socket at the right of the bed.
We would like the following switches:
Assuming it is correct, how do I buy such a 3 gang switch? The Hager range doesn't stock anything exactly like that. Am I correct in thinking that I should 'build' this switch using the 'Grid' range by ordering the following:
Background
My Question
- 3 gang switch at the door of the room where:
- button 1 controls the 2 pendant lights
- button 2 controls the left bedside 5A lamp socket
- button 3 controls the right bedside 5A lamp socket
- 2 gang switch at the left side of the bed where:
- 2 gang switch at the right side of the bed where:
- button 2 controls the right bedside 5A lamp socket
- 2 x 2-gang 2-way switch (for either side of the bed)
- 1 x 3-gang switch for the door of the room (where 2 of the gangs are 2-way switches and 1 of the gangs is an intermediate)
- 1 x Raised Plate 3 Gang Grid Plate
- 1 x 3/4 Gang Frame
- 2 x 20AX 2 Way Single Pole Switch Grid Module
- 1 x 20A Intermediate Switch Grid Module
