Discuss Dead RCBO? or Brain fart in the UK Electrical Forum area at ElectriciansForums.net
This could just be a Friday evening brain fart after a long week but,
Got home tonight to find the downstairs lighting cicuit has tripped, tried to reset the RCBO and it blew again straight away. IR tested the circuit, all fine.
While the circuit was disconnected I tried turning the rcbo on and re-energising the board and RCBO trips again. I took the neutral flying lead out of the neutral bar and RCBO doesn't trip. Like I say, could be my brain isn't functioning correctly and I'm missing something obvious or has the RCBO failed? Any thoughts appreciated.
What IR tests did you carry out L-E, N-E, L-N? and what were the results?were all of the circuit under test dissed from the CU?
Same as Wirepuller, if it trips with circuit live and neutral disconnected replace it with a new one.
I had a faulty MCB the other day where there had been a L-N short in a pull cord and they had tried turning it back on so the KA had got the better of it.
Sounds like the rcbo if it does it without the circuit connected, as already stated. Have you tried connecting it to another rcbo in the board.
Reply to Dead RCBO? or Brain fart in the UK Electrical Forum area at ElectriciansForums.net
Hi just wondering if someone can help me. I have an rcbo that keeps tripping but only when the fly earth and neutral lead on the bars it trips...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
