IslandK
Cowes
United Kingdom
Hi All,
I'm a working man relying on his van to stay in business - but of course it's developed a horrible electrical fault that needs more expertise than I can muster (I can do minor stuff ok). Vehicle forums have got me nowhere, so now I'm hoping you guys will be able to help:
I have a 55 plate Toyota Hiace 280GS with the 2.5 D-4-D engine. The van is low mileage (under 60k) and in excellent condition and I was hoping for a long life from it. However, on the day it passed its MOT and after a routine service, it failed to fire up. The engine turns over but the injectors are not firing. No warning lights show. So far the following has been done:
  • Earths checked and cleaned. Visual check made of all accessible contacts.
  • Fuel pressure checked in common rail and all ok.
  • Initial diagnostics suggested a fault or short in the EDU circuit.
  • ECU and EDU removed checked and passed ok by a specialist( they were even rigged to injectors which fired happily).
  • A check by an auto electrician showed a voltage spike in the ABS circuit. Removal of the relay saw the van fire and run, but only for a short time (presumably until the ECU had remapped the system?) The ABS was removed, checked and found fault free.
  • Further diagnostics suggested a fault in the canbus, with the resistance at one end of the canbus circuit reading 120 ohms and 0 at the other (it should be 60 ohms - two 120 ohm resistors in parallel reducing down to 60 ohms).
I have no idea what has caused this to happen so suddenly and don't really know what to do for the best, so I need somebody with an in depth knowledge of Hiace electrics or who has experienced a similar problem for some advice or thoughts please!
I'd be concentrating on that incorrect bus resistance. Can you narrow it down in any way? Maybe disconnecting as many things as you can while monitoring the resistance.
That's the frustration. All the wiring looks immaculate and there is no obvious damage point.
Often the problem. But disconnecting and testing would find faults that may not be visible.
Ok. That's a good start point, thanks. Is it likely that one of the can bus resistors would be down - i.e are they known to fail - or more likely that the resistance issue is caused by something failed in the circuit?
I'm not familiar with CANbus so would have to look into it. Having said that, it seems likely that either a short circuit or a faulty component or sensor could be dragging the resistance down to zero Ohms.
are these resistors accessible or buried within the loom?
Hopefully it's a component or sensor as you say - I'm not sure how I'd find a break in all that spaghetti!
Reactions: DPG
Can you get hold of a wiring diagram?
I don't know where the resistors are in the loom. My auto electrician felt they were embedded in the loom. Most modern vehicles have the resistors in the ECU (so I'm told), but my ECU has been tested off vehicle and is sound, so presumably so are the resistors if they are inside?
[automerge]1596229971[/automerge]
Researching that - nothing obvious on the net, but hoping Toyota will be able to provide one.
Reactions: DPG
But you are looking for a low resistance. This to me points to some other fault pulling the resistance down. Resistors don't normally fail by going low, they usually go high resistance. Not always obviously.
A systematic check of components does seem the sensible start point from what you say. Thanks for the insight.
Reactions: DPG
IslandK,
IslandK,
