- Reaction score
- 17,019
Coupling and bush on that pyro? (And any others)
Probably been there a while.
I think i have a good ~5m length home here already I'll check. Seem to come across it quite often here.Ooh R/W/B cable.... If you pull this out and it's more than a couple of feet, I'll pay you to send it over for the museum. Keep failing to secure any reasonable lengths of R/W/B.
I told them not to use the charge point and to get on to the installer as they should be given the chance to rectify.I don't know what I'd have done in your situation. As that's only a 60947-3 isolator the meter tails are effectively extended all the way to the EVCP....!
I've looked at this for hours and can't think of a reason.“Hi, wondering if you can help. Just moved into the property and every time we turn on any of the lights the electric trips.”
Hmm. I can’t think why! Can any of you more knowledgeable folk hazard a guess?
I’ve not even started on the rest of the place. Asked if they had a EICR done as part of the sale. Apparently one was done and came back as satisfactory.
So I’ve said they need to send these images to the solicitors and ask for their money back. Then I’ll come and do a proper EICR, which I’ve already pointed out a number of issues which make it unsatisfactory.
Well at least they tried to keep all of the armour electrically linked. Self-locking nuts as well!Can of worms
That is absolutely terrible, everyone knows you should use Gaffa tape as it's much more sticky.Not a dodgy trade. But more a Cupid stunt in the property.
Let’s just use sellotape to keep a circuit on that keeps switching off.
It was only the middle one (sockets) which was faulty and it was a faulty MCB.That is absolutely terrible, everyone knows you should use Gaffa tape as it's much more sticky.
One strange thing though is the Shed mcb looks to be the most stressed, and it's been left out, also wonder why all three ?
What about the shed one that looks like it's been cooked ?It was only the middle one (sockets) which was faulty and it was a faulty MCB.
Tested the circuit and it’s all fine. I can only assume the tape was over all three due to its size.
I wouldn’t mind but I went for non working underfloor heating. Which was also due to a duff fused spur.
It’s not. It’s just dirty. I thought it had too when I first looked at it. But there’s only a light and unused socket in the shed.What about the shed one that looks like it's been cooked ?
From the pic, it looks like it has a piece missing out of the bottom.It’s not. It’s just dirty. I thought it had too when I first looked at it. But there’s only a light and unused socket in the shed.
I replaced the faulty MCB and had a look at the others. Rest are fine.
Indeed it does. Never noticed that earlier . I’m going back tomorrow as didn’t have a fused spur on the van. So will replace it and then get myself an eye test.From the pic, it looks like it has a piece missing out of the bottom.
