M
Matthew168
Hi,
can anyone recommend a good lighting controller possibly 4 zone for general domestic use?
thanks
Lutron every time
only issues is with min wattage of 40w per zone, prob is i want to use LED lamps !! :(
That's what caps are for, just don't tell the Part L police! :D
Thanks for the advice, will look into the lutron tomorrow. Have fitted a futronix unit in the past but seem to remember it was quite pricey
Hmm... I have seen they do load resistors
But that sort of defeats the object of using low energy led lamps
On two of my zones I'm only running at approx 20W
Not tried it yet though, it might work okay if I set the load type from resistive to capacitive in the config menu on the lutron panel ?
Yeah, you're right it does kinda beat the objective of trying to be energy efficient. To be honest though, in smaller domestic settings if you are looking for energy efficiency you wouldn't be using Lutron would ya :D If you're looking for it to provide an energy efficient solution it only really comes into its own in larger commercial applications.
Domestic lighting controllers
Domestic Electrician Forum
Matthew168,
Dohnut,
