Discuss downlighter conundrum in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
cossie362
hi guys
quick question regarding downlighters with no fire hoods in a top floor flat
building is 15yrs old requires a periodic before bein let out on the new deic reports would this be a code c3?
i think so,even worse as well if there is loft insulation,but its a small cost fix for the owner and a must.i have seen people use flower pots before!!!!
agree with rich.250. just move insulation away. no code.
and they don't have to be fire rated downlights either.
what i have used in the past to protect the down light from the insulation i a plastic terminal that goes on top of soil pipes etc just bend the retailing legs over place over the down light an stick like sh** to hold it in place works a treat
Think I'm right in saying only require fire rating between floors, (If there's a room above) to stop the spread of fire to a habitable room, if it's a loft above then no fire rated fitting required, just clear insulation around the fitting..
Personally I always fit fire rated downlights no matter where they are installed, common sense sometimes has to take over here, I have seen many bags and Xmas tree boxes thrown into a loft hatch and resting against light fittings..
Fire rated would be my choice, and there required in a dwelling above 2nd storey If habitable. E.g loft conversion.
Or if it's a separate dwelling above. Flats etc
But this is irrelevant to EICR as its a building regulation.
I was pulled at my elecsa inspection last year because I'd fitted fire rated downlights in a Ceiling with a loft above, cut around the insulation and not fitted hoods. I was told that I must always fit a hood and use heat resistant flex to the fitting. I was surprised but there you go.
yeah. i would have asked the assessor for the reg. no.
If I get him again this year then I'll be asking him. I feel a bit daft now for just going along with what he said (respect your elders and all that). Watch this space for an update.
Reply to downlighter conundrum in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi all Called to do an EICR on a property 4 studio flats / bedsits within a single house. The t&e sub main to each flat runs within the fabric of...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
