Discuss Downlights in kitchen have to be fire rated? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
for the small differenc in cost i would use fire rated, but i think the regs. only insist on fire rated if the floor above is occupied by different owner/tenant
You will find that fitting Caps on downlighters is normally done when you need to keep the integrity of the fire barrier in flats and multi occupied dwellings.
If you live in a single dwelling ie your own house or bungalow you don't really need to. Like quite a few sparks I still would fit them just as a safety aspect as any cable egress should be sealed
Apparently it isn't just about fire barriers, there is an issue with building regs about sound barriers which apparently fire rated fittings overcome, and the way I understand it with the fire situation is that (as mentioned before) in a normal 1 or 2 storey dwelling the fire barriers don't come into it. I have no official rules that state this, but for the difference in cost I always fit the fire rated ones (unless in a suspended ceiling maybe). I reckon that they are better aswell, as no light escapes around the rim.
Agreed
Reply to Downlights in kitchen have to be fire rated? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
Hi there I have 8 downlights in my kitchen, 6 on one switch and 2 on another (not sure why), I've replaced the downlights on the 6 and they work...
Just saw a vid of someone putting in a CU on unistrut in a domestic property (why, i don't know), and one of the comments said it fails the regs...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
