Discuss earth ground spike in the UK Electrical Forum area at ElectriciansForums.net
J
jammar
hi
i have just been to look at an installation that needs a ground spike.
i have never done one before , apart from the spike do i need to do anything else to make the board comply. Do i need to change the rcd?
thx
Hi Jammar. I've removed the poll from your thread because it isn't really a debate that lends itself to voting so it would have probably caused confusion.
as Richard has said , i know this may seam a daft question but is it a TT system what is the current earthing arrangement picture may be good
A photo or two of the existing earthing arrangement and the head etc would be good.
Usually the supply authority or DNO would provide an earth with the supply. If there's an existing system that isn't suitable for PME then adding extra rods could be dangerous so make sure you're 100% clear on the existing arrangement before you do anything rash.
This thread could turn into a Banana skin for the OP IMO, Best to move it to the trainee section or away from harms way, I can see it turning sour.
Early days yet, maybe he can pull a rabbit from a hat when he gives us more info. You never know, maybe he's TT'ing the installation because of a vehicle charging point or for some other valid reason. Unless you're currently on a course (or apply as a mentor) you won't qualify for the trainee forum and he doesn't really sound like a DIY'er.
can't imagine Spike standing for being hammered into the ground.
spike.jpegc
Reply to earth ground spike in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
