Am I right in saying that if there is no earth connection to the suppliers cut out then the earth type is TT?
We have just moved into a property and there are currently 3 fuse boxes connected. All have a connection to the met which is not connected to the cut out. One does the majority of the house, one is for the garage and one much newer one is just for the cooker. The cooker one has a 30ma rcd and a 32 mcb in it. the garage one has a 100a main switch and a 40a mcb. Both of these boxes are labelled but the main one is not and has a number of circuits split between the main switch and an rcd. I have been told that if it is a tt system then the whole lot should be rcd protected and there is a lot that isnt. Is it possible that this is a different earth system and is it likely that its safe? Landlord just says it works dont worry
