Discuss eicr tick sheet in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If you are having problems with the tick sheet why are you undertaking an EICR?
Sorry to sound so scathing, but that's the easy part.
Sign up for the course which replaces C&G 2391-10 (I don't know the new number!) as a starting point!
did the course about 3 months ago but the tick sheet at our work place is about 50 boxes,the other day i put a not verified on a fire isulation box because i couldnt see all of the outlets and was told to tick it i asked why and the qc said because im told you too..... ive been testing for 27 years and had no problem with the pir its just the wording i want claified. cheers
I would print off the tick box schedules and have a read of them.
Each item comes with a regulation number in brackets which you can look at which will jog your memory as to what is required!
When you first start to use the form it can be a little confusing but it will get easier IMO !
More info at the beginning would have been nice, you could have been on about alot of things and if the Qc wishes to change or alter any of the sheets without telling you why then tell him to sign his name on it instead. If the tick you are asked to put is incorrect do a copy before you show him and keep it on file that way hand him the sign off sheet and if anything ever comes back at you you can review the original and not a doct' copy
You wouldn't want to hear my reply to someone who told me just to tick something on their say so, sounds like a right jumped up twit that needs a good tick tick tick BOOOOOOM on the nose!
If you want some good books, then the NICEIC do 2 that i can highly recommend. Inspection, Testing and Certification inc Periodic Reporting 6th edition, and Domestic Periodic Inspection, Testing and Reporting 2nd edition. They were on special offer a bit ago, and you could get both for about £30. I use these as additional reference material when i deliver the 2394 and 2395 courses. They go in depth into completing the EICR forms.
Cheers.............Howard
Reply to eicr tick sheet in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
happysteve submitted a new resource: Circuit details + test results - extra sheets for EIC/EICR - BS7671 2018 + A2:2022 - Fillable circuit...
I've booked in an electrician to run an EICR, I have an old unit here, whilst searching for quotes one guy said it looks ok and may not need...
