Discuss Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
Spark just put in a electric shower (Triton) and hit a small problem, black brick wall behind the tiles where he wanted to install.
He said not to worry, he will just trunk it up into the ceiling (which goes into the loft). To do this, he cut a hole in the top of the shower box. He hasn't sealed the hole, there's a rough 0.5cm to 1cm gap between the hole and the trunk, and the trunk isn't flush or sealed against the tile wall.
Looks like water could very easily splash into the inside of the shower box through these gaps. Is this safe? I am going to seal it myself but want to know if this could be a serious issue or not as he left it.
Thanks for your time.
so what's the other side of the black brick wall? does new shower have RCD protection? several worryim
ng points in OP>
Hi - yes a few pics will help :) .
There are entries designed to be cut out in the top, but what we can't say is how well that's been done.
Thanks for the replies!
I've attached some pics.
Inside the trunking is the water pipe and the electric wiring. He didn't feed anything into the wall as its black brick then into the master bedroom.
It looks like he has used a tool to cut the hole required, the edges are rough and hopefully you can see no attempt to waterproof the hole was made.
To answer some other comments:
We have RCD in the flats fuse box.
There was no electric shower in place before, but the circuit was there. The pull chord for the on/off for the shower was in place and now serves the new install.
Did he arrive on a horse? That’s appalling. He has negated the IP rating of the shower.
Water will get in, it will cause problems.
I really hope you haven’t paid him.
First of all, please DO NOT use the shower until you are 100% sure it’s sealed and safe to use. Was the electrician you used a member of a competent persons scheme?
He was dispatched via the landlord, no idea re his credentials or affiliations. He has been used by the landlord for years as far as I know. He installed our new rcd fuse box 2 years ago and replaced most of the lights in the flat this week as well as installing an extractor in the bathroom as well as the shower.
Reply to Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
Hi there guys. I am working as a maintenance electrician in an office block. There are Shower rooms on some of the floors, with electric shower...
