Discuss Emergency lighting in the Australia area at ElectriciansForums.net
B
Barker
I have been asked to quote for installing some emergency lighting in a nursery school, the issue is the CU is already full to bursting with no spare ways. Currently the exixsting lighting is only on an MCB and not covered by an RCD so there would be no nuisiance tripping, so the question is, is it perfectly ok to just hook into the exsisting lighting circuit?
TA!
560.9 Directs us to BS 5266
According to BS5266 "[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]The source of supply should be from the same local fuse as the normal lighting, so that in the event of a fuse failure causing the normal lighting to be extinguished, the emergency lighting is brought into operation in the same locality."
You can read the BS here Emergency Lighting Design Guide
Hope that helps
[/FONT]
Reply to Emergency lighting in the Australia area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Two lighting circuits covering various communal areas on two floors of a HMO. The non-maintained emergency lighting that covers those areas is on...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
