@theshaniqua crude edit....
It's still wrong. PL and SL must tap into the brown and grey of the same strapper cable. Imagine they were paralelled at one of the 2-ways, and then just transferred to the other end of the same strapper cable.
Yes. I think manufacturers are inconsistent with labelleling L1 and L2 on intermediates. Traditionally I recall it being L1 for both 'brown' terminals and L2 for both 'grey', but have seen drawings as per yours with L1 for both terminals facing one 2-way and L2 for both facing the other. Perhaps someone could confirm? I don't usually install light switches so it's ages sinnce I looked at one.
You're right, they do vary from manufacturer
They certainly do. More or less any combination you like ?
The common theme seems to be a terminal at the top gets connected to one or other at the bottom ?
(as you might imagine from the construction of the thing). Amongst others Schneider go for L1, L2, L3, L4
My bad I didn't notice that
old thread.... but let me ask you what you mean...
"3g" meaning 3 gang? one plate with 3 switches on it? Yes.. just treat each switch as individual switches. You do not get an intermediate in a 3 gang unless you build it up with grid modules with separate switches... you could have any combination. otherwise, a 3 gang would be 3 x 2 way switches... The intermediate would have to be at another switch location.
In America, they call the UK "2 way" switch a "3 way" Which is just confusing...
Let us know your problem, and we can help a bit better
although its ages since I tried I'm sure you can get a click mode intermediate switch, unscrew the module and screw it into a click mode 3 gang switch to make one of them the intermediate.
As for the wiring, the feed and switch T&E wiring on a 2 way circuit go into the L1 and L2 connections of the switch along with two cores out of the 3 core&E (strappers), think about that, the feed/switch is connected to the strappers, it doesn't know where its connected it's just connected to them, therefore they can be connected to the strappers at any point in the circuit, at one end, at the intermediate, at a junction box at some point in the circuit.
