Discuss Feeling dumb megger and voltage indicators in the UK Electrical Forum area at ElectriciansForums.net
At a light in my home, I have a voltage tester with two probs and a multifunction tester borrowed from work
The voltage Indicators shows continuity and beeps between live and neutral
But then multifunction set to continuity shows greater than 1000ohms
What am I doing wrong xD
When you say the VI showed continuity between L and N nit sure what you mean
As Tel has suggested, a connected load would cause this.
what megger that you are using ?.
[automerge]1580298346[/automerge]
may be you need to understand the tester and testing .
he can borrow mine:
Reply to Feeling dumb megger and voltage indicators in the UK Electrical Forum area at ElectriciansForums.net
I am wiring up a new kitchen and conservatory. I'm not sure why I checked continuity between line and the metal back box of the light switch, but...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
