shaun gold
I'm having an on going argument with fire alarm engineers that run the 230 volt supply for the panel along with the fire alarm circuit installation (more often than not, clipped together in the same trunking). Both are in FP 200 cables but should they be
separated as you would normally. Does the fact they are both insulated to the same rating make it ok or would there be
Interference to the fire alarm circuit pulses by possible EMF.
