Discuss Fire Alarm in the Commercial Electrical Advice area at ElectriciansForums.net
In what respect fitting automatic detection in the lift car or lift shaft. If in the lift car I don't see why not but I would connect it to its own zone but you may have issues with its connection. It is a requirement of BS5839:1 to have a zone plan at the control panel.
Thanks. Theres a new lift been fitted and the lift company are looking for a io at top of shaft beside power supply. Have not asked them yet but I presume its to stop the lift in case of fire. Just checking as the fire alarm is a conventional type.
You can fit one in the shaft connected from a conventional system. Normally a suitably identified remote indicator is fitted to give notification it has been activated. It will not stop the lift however some complex sysyems can default the lift to a safe level.
Sounds like they are asking for a relay output from the fire alarm, if that is the case the question needs to be asked what cause and effect this will give as driving the lift to a specific floor may actually take people in the lift into the fire.
Heard of something similar a while ago this site had an addressable panel so there was a work around, the lift default in case of a fire alarm was to be the ground floor somebody then came up with the what if the fire is outside the lift on the ground floor, the setup was then changed if the fire detection indicated a fire in the location of the lift exit on the ground floor then the lift was programmed to stop at another floor
I think the fire risk assessment (assuming you do these in Ireland) needs reviewing before this goes any further and the function of I/O needs to be understood
Reply to Fire Alarm in the Commercial Electrical Advice area at ElectriciansForums.net
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
