Just to clear out a few points to understand where I'm coming from:
I work in IT (Comms) where the work has to be planned very methodically to make sure you don't f*** up, leaving a few thousand users having a long break while you try to fix it. Then I a'm bit of control freak...Probably you know that by now.
I'm not Polish, I'm Spanish instead.
I'm not going to do the CU move myself. The Polish electrician will do it, I got a few things done by him in the past and he's been completely fine.
I'm trying to get everything organised before he arrives to install a CU to find this doesn't fit, with the clock ticking and money running out of my pocket.
You probably think...leave it to the professionals but I'm just planning and trying to understand as much as I can to avoid mistakes.
My partner and I have been saving money for the last 8 years to get to this point and as you can imagine after all this effort we want to do things right.
Don't scrimp on the electrics, I only use Schneider or MK boards as there top quality and parts readily available. Your Electrician should be advising you about all these questions you are asking as he can see everything onsite. He should be able to determine the layout of the circuits in the board and advise the best options, have you had an EICR carried out at all? £250 seems very cheap and I wouldn't install a BG board, cheap and nasty. I usually charge between £400-450 including full EIC, do your water and gas bonding need upgrading? When it comes to electrics pay a professional to do the work and make sure there a member of an organisation such Stroma, NICEIC, Elecsa etc, you will pay more than £250 but at least the job will be done properly and you won't have to keep posting on here asking questions.
Doing things right, avoiding mistakes, and saving money, does mean leaving things to the professionals. The right professionals who are fully aware of the electrical regulations and legal requirements of this country. You need to verify you will be getting an electrical installation certificate and a building control certificate. You can research if your electrician will be able to notify building control without added cost or complication to yourself.
You might want to have read of this thread then;
Few questions for an electrical installation - http://www.electriciansforums.co.uk/threads/few-questions-for-an-electrical-installation.122134/
whats wrong with that board? its got the stab bus bar so just buy a selection of crabtree rcbo's to stick in it? better to do that if your on a budget than buying some BG piece of garbage
Suffolkspark is right, you have an 11 way starbreaker consumer unit, you just need Crabtree Starbreaker RCBOS for all the circuits. Bin the old style 2 module RCBOS to maximise your capacity at the ccu.
I would be a bit wary if your Pole didn't point that out straight away. :pileofpoop::speaknoevil:
Reactions: Rpa07
Taking all of the guts out and replacing them puts it into dubious territory on the non-combustible CU front. Especially considering that, as far as I know, the whole lid is plastic not just the window.
  • Agree
Reactions: Dave OCD
It's existing and if not in a sole means of escape doesn't even warrant a C3 on EICR so IMO perfectly upgradeable and useable and a better option than to replace with some piece of s*** BG unit which I'm pretty sure we all know by now isn't going to get tested properly either!
What guts?
And wasn't you waffling on about no such thing as non combustible the other day? :tearsofjoy::tearsofjoy:
Honestly the people that post on this forum, you wonder it they ever worked in the real world ! :flushed:
  • Funny
Reactions: DPG and Rpa07
Old CU's and new RCBO's are some times compatible, as long as you seek manufacturer guidance first. However, I fitted two Hager RCBO's in one of their older CU's, and there wasn't a lot of room for the wiring termination.
Some manufacturers offer RCBO populated CU's, which are cheaper to purchase than individual devices, and the CU has been designed for RCBO's.
^^ that board DOES NOT have RCD's it has rcbo's
Read my earlier post - it's obsolete - and needs changing ....
Actually given that RCBOs are a type of RCD it most certainly does have RCDs. It doesn't have any RCCBs however.
Sorry davesparks I hadn't seen your post when I posted that.
Boys ......... the vast majority of Joe Public don't understand the differences ........ so I stand by my statement (and I don't think the later versions of the RCBO will fit that board ).
The OP needs a new CU............. end of.
  • Agree
Reactions: telectrix
i agree. due to the busbar layout on these boards, it's next to impossible to re-configure them.
What's to reconfigure? This board has no RCDs, it's a Crabtree starbreaker board with a main switch. Remove the mcbs and the obsolete double module RCBOs and replace with modern RCBOs. Gives the Op all the capacity he needs.
Once again, that statement simply isn't correct. RCD is a generic term for all residual current devices which includes RCBOs.
:weary: I thought it was pretty obvious I meant a double pole type of RCD used to make a ccu split load or 17th edition......... But you are absolutely right to pull me on it. (And technically correct is of course the best kind of correct :tonguewink:)
I apologise for my tardy parlance and will strive to be clearer in future. :laughing:
  • Funny
Reactions: Rpa07 and Risteard
What guts?
By guts I am referring to the internal parts of the CU.
I don't know if I was 'waffling on' but yes I have often commented on the fact that everything is combustible if exposed to the right conditions.
If and when I make that departure from the regulations I do so after considering the individual situation, not as a one size fits all solution.
What guts?
Just to let you chaps know , did some one ask about moving a consumer unit in scotland in bunglow recenty on this forum?
Come on buzz, there's nothing much else happening.
  • Funny
Reactions: Rpa07
Is the existing board metal clad?? If not then the board needs changing to comply with current regs.
To give my opinion;
If the replacement items change the original installation, e.g. dual RCD to fully populated RCBO's, then I would consider that a significant change to the original installation, therefore would need to comply with current regs (i.e. 421.1.201).
If the installation was the additional RCBO or two, then it would not. We did have a recent debate on moving a plastic CU from one room to another, which I think came out 50-50.
As I said earlier, it is probably more financially viable, to install a new A3 fully populated CU, than just buying x amount of RCBO's to install into a plastic one.
Bottom line is, there is no one who can tell you how to interpret this reg in these circumstances, and unless you find yourself gripping some bars, being questioned about your reasoning, you can do what you think complies with this reg. :)
Edit; you could ask your scheme if your in one, but I suspect they would bat it back to you, and say it was the designer to make the decision.
  • Agree
Reactions: Rpa07 and Billsays
Really? please explain.
Let me explain, you are moving the board from one location to another. You will be disconnecting all the cables and supply to the board. You want to strip the board down so you can try and fit suitable rcbo's. You are installing it in a new location. You must comply with current BS7671 regs. The work must be notified to LBC. The work must be done by a qualified Electrician who is a member of a scheme so the work can be done properly, to current regs, certified and notify LBC. If you want yours electrics done right and have no issues later on if and when you want to sell the property then pay a qualified Electrician to do it right, if your not going to do that then stop asking questions on here and ask your own Electrician who's charging you £250 and on about installing a sub standard board. Good Luck.
  • Agree
Reactions: stevethesparks
I,m more in the camp of post #50.
Your making it sound a bigger job than it actually is. Existing CCU is perfectly up-gradable.
i may be wrong here, not having used a starbreaker board for ages, but aren't some of thos busbar slots Neutrals for the D/P RCBOs?
Do what you want, I've only been doing Electrics for over 20 years, done an apprenticeship etc. What do I know, but don't come posting on here when you can't get it signed off because you have used a plastic board and not a metal clad one as per the regs but what the hell, just do what you want.
Let him find out the hard way as he keeps telling us what he's doing even though he's not qualified, his polish electrician can determine that.
  • Agree
Reactions: buzzlightyear
:joycat::joycat::joycat:Calm down mate, Ive been doing it a fair bit longer than you and know what i,m talking about.
The op is fishing on various sites for info........does the mystery polish electrician exist? I doubt it. I'm just debating whether the existing ccu can be re used.
No starbreaker are not obsolete.
i stand corrected. just was looking at a couple of RCDs i have in stock from a strip-out. 2 porongs, but the N is separate so those 2 prongs must both be L's. if that makes sense.
Sorry I thought you where the OP, my apologies, he just needs to sort it out with his electrician and stop posting on every forum under the Sun, again sorry, I've had a carp day with a carp CPN board that shouldn't even be allowed to be sold.
Reactions: seltechpc
No worries mate, it can get confusing who says what!
Can't stand those cheap boards, CPN, BG etc i think they are the reason Amendment three was introduced! Is CPN Citys own brand?
Reactions: MerlinGremlin
in ref to post #75 yes but the 1 module ones fit. the bus bar is continuous in these boars, they had plastic inserts in the split load ones but this is a straight bar so nothing else in the board needs changing. lets face it its not going to get a certificate on anyway that's even if this polish electrician exists, I would much sooner a DIYer use that crabtree board over a new BG one as he's got a third more connections to potentially leave loose with his neon screwdriver!
FIRST HOME - Help with new Consumer Unit
DaniQ,
Midwest,
