Discuss Flat supply wiring and fuse protection. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This is where I get my balls busted on this forum, I think the 6mm2 earth wire in the 16mm2 T&E is not adequate regardless of the adiabatic equation, thats if it does actually pass which I doubt,There is a thing as good practice in my view and rollocks to the regs, seriously rollocks to it, I always run a 10mm2 earth wire with a 16mm2 Twin and Earth for the main supply to a flat and usually connect it via a KMF switch via an 80 amp max fuse, a 60 even better if there is minimal load, you get slated on here for suggesting running earths with sub-mains haha, but I have always done it this way and always will.
I dont understand why you should get slated for running additional earth conductors with your submains. nothing wrong with going over the top, belt and braces as we say in yorkshire.
In almost all cases of industrial electrical cabinets i have worked in, have had a nice big juicy separate earthing conductor run into them, so why not flats and houses?
Cheers..........Howard
How are the sub mains cables,insulation readings good?,if it were me id do the same as you so a 3,the install is existing and as mentioned by some of the more seasoned sparks "retrospective" so our own preferences to one side,3036 is still recognised obviously as a safe means of circuit protection,i did an old PIR for a firm i used to work for and the boss said dont test anything with a 3036,this was a factory and he couldnt even give a correct explanation as to why!
the only problems with 3036 fuses are that
a. they de-rate the cable capacity by a factor of 0.725
b. they arent great for short circuit protection
c. its difficult to determine the rating of the wire link above 30a.
Reply to Flat supply wiring and fuse protection. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, quick question - I have to replace a lateral supply cable where the existing one runs through the ceiling of the basement flat and up...
Hi Fellow electricians, I’m recently qualified and I would like clarification on swa supplies for flats, my boss says this is okay but I’m not...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
