- Reaction score
- 63
When metal pipework is going out of the property into a metal meter that is in the literal ground, i'm bonding it whether the supply for the meter is plastic or not.
Discuss Gas bond, plastic pipe but metal into properly in the UK Electrical Forum area at ElectriciansForums.net
Was, nt posting that to contradict what you said. Felt it was appropriate to the tread. Like you,I would feel that if an unextraneous part becomes extraneous, then something needs to be done about it.When metal pipework is going out of the property into a metal meter that is in the literal ground, i'm bonding it whether the supply for the meter is plastic or not.
Yeah mate no dramas.Was, nt posting that to contradict what you said. Felt it was appropriate to the tread. Like you,I would feel that if an unextraneous part becomes extraneous, then something needs to be done about it.
Good Post. I might differ slightly on the reasoning over the lpg cylinder. If as often is the case its metal bottom is sitting on concrete than its in better contact with true earth than a person outside standing in his shoes and socks.Similarly a lpg connection to external cylinders doesn't - but if said connection went underground to say a large tank/cylinder then it would.
Reply to Gas bond, plastic pipe but metal into properly in the UK Electrical Forum area at ElectriciansForums.net
