Discuss Help fitting new light fixture in the DIY Electrical Advice area at ElectriciansForums.net
donski
Made the massive mistake of not taking a photo beforehand and am now stuck with a light fixture that I'm not sure how to wire. I'd removed an old light/fan fixture and had to remove one of the terminals and some wires in order to remove the fixture fully. I've attached the after photo in the hope someone can tell me how to wire it. There was an extra connector which fed a live and neutral to the light.
Appreciate any help or advice!
The chances of anyone here from afar confirming how that was connected is going to be pretty slim, we would be guessing. You are going to need an on site electrician.
Reactions: DPG
Reply to Help fitting new light fixture in the DIY Electrical Advice area at ElectriciansForums.net
Led light fixture went dim. I replaced it with a new fixture and it won’t power on. I have 120v with a multimeter at the wire. When I wire up the...
I have an inground pool with a 22 year old, 120vac light fixture in a niche connected to water-holding conduit running to a switch in an...
I'm trying to install a pendant (single bulb) in a ceiling light fixture. I've run into an issue with the wiring of the fixture box. Here's the...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
