Discuss Help!!!! Metrel Mi3000 tester problem in the Electrical Tools and Products area at ElectriciansForums.net
J
junior-sparky
Finshed and install in an unoccupied building today and went to do the testing and my meter decides to play up.
I always like to do my RCD test first (nothnig like the sound of the click to know it's working) but upon the auto teest at 30ma it stops at x1. another issues is the RCD would trip when trying to do a zs of the 2 rings (set to test with RCD).
I have a shiney new house and tried the 2 tests on my board and exactly the same issue!!!
Has anyone else had experience of this and is my meter dead or an easy fix?
I should add that i used both the 3 pin plug lead as well as the kewtech 3 pin adaptor but same issue.
It was only recently caliberated ..
cheers
best contacting Metrel directly. your meter is certainly not dead, it maybe just some simple patch on firmware or something like that. They all microprocessor controlled this days.
side note: testing rcd first at the beginning is useless, it may not operate correctly when there is messed up wiring (insulation resistance, continuity) or some faults with the earthing system (Ze!)
Try removing the batteries for about 10 seconds, and try again. Obviously make sure that settings have not been altered and that the "G" appears in the type section of the window and is also set to 30mA - these things can be easily overlooked if altered accidentally.
I've a video on the forum somewhere of updating the firmware yourself if you don't want to send off. It does have the disclaimer that it is possible to brick the tester if something goes wrong though.
The Metrel Mi3000, I believe will only test type A RCDs.
I don't think it will test type B RCDs.
What type of RCDs are you attempting to test?
Tosh! The mi3000 tests type B no problem..
Are you sure the "rings" are definitely ring circuits? Also try the trip test on another circuit eg cooker, or lights. You need to do all other tests first really because there may be all sorts of problems with the circuits.
According to the manual it is only intended to test type AC and A, not type B. So it cannot be relied upon to test a type B RCD correctly.
Reply to Help!!!! Metrel Mi3000 tester problem in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
Hey guys I'm studying at college at the moment. I am looking to get some essential electrical testing kits slowly. Is a multificunctional tester...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
4K
