J
junior-sparky
Finshed and install in an unoccupied building today and went to do the testing and my meter decides to play up.
I always like to do my RCD test first (nothnig like the sound of the click to know it's working) but upon the auto teest at 30ma it stops at x1. another issues is the RCD would trip when trying to do a zs of the 2 rings (set to test with RCD).
I have a shiney new house and tried the 2 tests on my board and exactly the same issue!!!
Has anyone else had experience of this and is my meter dead or an easy fix?
I should add that i used both the 3 pin plug lead as well as the kewtech 3 pin adaptor but same issue.
It was only recently caliberated ..
cheers
cheers
