Discuss how do you work out maxium demand in the UK Electrical Forum area at ElectriciansForums.net
The way I used to do it was 100w per lampholder add them all up and divide by the supply voltage to give the amps,that was when we had lightbulbs on pendants before all these fancy fittings came out so 10x100 =1000 divided by 240(supply volts)=4.16a
then its 66% of this therefore maximum demand is 2.75A
table A2 on page 111 of the on site guide.
in the on site guide it says it 66% of total current demand how do you work it out by that
Work out your total load in amps by the formula given above then multiply that answer by 66/100
To be brutally honest this is pretty basic maths mate and if you struggle with percentages you're going to have a fairly major problem
Reply to how do you work out maxium demand in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi All DALI lighting system distributes circuit via LCM's, for electrical test, do you stop at the LCM or light point. how do you carry out...
Can someone explain to me with a sketchy circuit as how a photocell we install in homes for fence lights actually works. Animation video or normal...
Hello everyone! I have a question regarding the electricity supply and the maximum demand. One energy utility supplies an 18 kVA maximum...
