Discuss I was testing the thermostat in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
1stfix2ndfix
and it was in a bit of a tight space the crocodile clip had lost it's grip a bit and kept slipping of the earth terminal so I was really trying to force it on. When I went and put the live and neutral probes on to the live and neutral (in) of the switch it went bang!
Obviously I've learnt a lesson here that if the crocodile clip is touching the earth and the live? and you put the probes on it goes bang. The thing is I'm not sure what really happened and why
sounds like you put them on live and switch live perhaps.
No, he said he was using 3 test leads.
The imm heater makes sense though, I've been trying to work out how a roomstat has ended up in an awkward place to test it!
But if it is an immersion heater why on earth wasn't it switched off whilst the probes were attached and then switched on?
I presume that you're an apprentice and learning the trade? If so why weren't you shown how to carry out the test that you were doing? If you were unsure, why didn't you ask your supervisor.
What test were you trying to carry out? Why were you doing live testing without supervision?
As above, very vague info. Are you sure it was an earth as plumbers are known to use cpc as another conductor if they need one and still use g/y sleeving if sleeved at all!!!
I've got a quick ten mins
yes I'm working as an electricians mate. I don't want to ask him to many questions as I don't wanna slow him down and loose me job.
But he did say I must of had the crocodile clip touching the earth and live terminals.
it was a earth fault loop impedance test so it was live, yes it was a immersion heater and I tested it at the switch. Once I had secured the earth to the earth bar only or at least that is what I thought! And then put the probes on. One on live the other on neutral (supply side) I saw a big blue flash and then some black smoke. It also went bang. I'd like to know what happened and why it happened if anyone can help It would be appreciated
had you got meter set to continuity by mistake?
Same thing happened to a lad I was showing how to test ELI on the back of a FSU. I said "Whatever you do, don't short mi probes by catching them across live and earth. " Sure enough he took a chunk out of my probe.... and it did make a nice bang. It happens... So if there is a chunk out of it and everything still works... there you go, if not I have no idea.
No as there quite old testers. I think what has happened is that as I've put the crocodile clip on the earth and then twisted the switch to put the live and neutral probes on I must have knocked the clip so it came into contact with the live and that's when it went boom. I'm not sure why this happened as in it went boom but someone might be able to explain why? If it was live and neutral I've been told it would go bang to but if it was neutral and earth it wouldn't.
Yes the switch was fine a bit black from the soot but it all worked ok. The testers were fine as well they still worked as we've used em today. There bloddy old though. Instead of it being a multi function one we've got 3 seperate ones.
If the meter is still working and the switch is still working then the likely explanation is that your probe / crocodile clip came into contact with two conductors and shorted out the circuit, either between line and neutral or between line and earth.
The high flow of short circuit current will cause the bang and the smoke and the soot ( and presumably a couple of melt points on the probe!).
Reply to I was testing the thermostat in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi all, just a quick one to ask about an issue I'm having with my EV charger. I'll give a little background first but ultimately I want to know if...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
Hi, Bit of a strange one today, was using a single socket extension lead and I plugged my hoover into it, turned it on and it started up very...
