Discuss Installing a dimmer on what looks like it was a 3-way, previously. in the DIY Electrical Advice area at ElectriciansForums.net
ddd777
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR)
Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also a ground)
The Red and Black are both ALWAYS HOT and the White becomes HOT when the current switch is turned on.
Which terminals should I attach which wires to on the new switch.
Not sure how to figure out what is the "common" and what the "travelers" should be.
FWIW, I am guessing it was a 3-way before at some point and that the other switch is buried in a wall somewhere...
Thanks in advance for any insight.
It appears that the black and white are being used as travelers.
Reply to Installing a dimmer on what looks like it was a 3-way, previously. in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi everyone. I bought one of those smart switches, specifically the Kasa 3 way kit (HS210 KIT). But when I opened my 3 way dumb switches I see...
Hello, Question for the experts since I haven’t had this problem before. Working on my sons house installing a 3 way dimmer. Attached is a photo...
I have a staircase about 25 feet long with two recessed lights (one up top, the other at the bottom). Each light is on its own 3-way switch, which...
