Discuss Insulation Resistance - Low Reading on Ring in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Something somewhere in there mate.....welcome to the world of testing in domestics, good luck I’m sure you’ll find it and keep us posted ?USB Socket has already been disconnected (downstream).
There are several neon double pole switches for the appliances which I already turned off (not disconnected).
I've disconnected the sockets downstream of the neons and still getting the low reading.
It's the Neons', causing the low IR readingUSB Socket has already been disconnected (downstream).
Some only have SP switches though Telneons should not affect readings if the FCU/D/P switch is Off, as they are (should be) on the outgoing terminals.
Reply to Insulation Resistance - Low Reading on Ring in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
