Shaun H
I found this JB in the loft, the mice have eaten the JB cover as well as some of the wiring, but aside all that in your opinion do you think the JB is overloaded?
How are we supposed to know whether it is overloaded without additional information.
We can't say if it's electrically overloaded, but at least one terminal is mechanically overloaded.
Irrelevant, since the fixing point for the cover is totally broken off, and it needs replacing ASAP by a more modern junction box, suitable for the number of cables present, such as a Wago box and connectors.
Hmm continental 7 on the bottom right grey cable with a double cross through it, wonder if that is indicative of the installers origin.
The orange 2 core lawn mower flex is also a possible cause for concern, as there is no earth (CPC) in that cable.
Reactions: pc1966
I didn't know mice were into bakelite.
No way has that been nibbled. Smashed and lid dispatched by a cack-handed DIY merchant, more like.
Yeah some ham fisted sparks added a cable and couldn't get the lid on properly so just mashed it up and chucked it most likely
  • Agree
Reactions: DefyG
I think any sparky worth his salt would be replacing that. I'd advise getting someone in.
Are there any earths on any of the circuits? But if this a spark asking the question back to college for you
We have power in and power out complete with earth wires, plus the switch and lamp wires for two lights, all without cpcs, and then the orange flex feeding a second lamp on one of the circuits.
All, except the flex, pre 1970.
I expect your looking at 60 years old wiring maybe you should look at getting it rewired
That permanent live term looks juicy.
OP. Any idea who's numbered the cables?
To be fair it is old twin cable with no cpc so in reality I would be looking at a re-wire sooner than later
Very likely the comedian who added the orange flex, since it's numbered, and not the highest number.
Logical my Dear Watson. I like it.
Hopefully the OP has got someone to replace it.
As for the JB would be better to have used 6terminal ashley 601, good quality JB.
They look to be in nice numerical order, to me. Nice, neat job.
Fitted dozens of them, back in the day, but there's better alternatives now.
Wagos with the silly little enclosures, not big enough IMO with that amount of cables.
If the 'silly little enclosure' is not big enough then you have selected the wrong enclosure, it is hardly the fault of the product if you have selected the wrong thing.
Thats exactly why my chosen would be a 601 JB #18
Reactions: Electro-tech
There are CPCs there, can't tell if they are in every cable or just most though.
Two cables have cpcs, and will be power in and power out. The cables without cpcs go to two switches and originally to two lamps. Standard wiring arrangement at the time.
Orange flex is a second lamp in parallel with one of the originals.
  • Optimistic
Reactions: Mike Johnson
Reactions: nicebutdim
I can't think why someone would use a screw terminal JB these days, when it's far quicker to wago type and make it maintenance free, whether needed to be or not.
As most of the cables are Red & Black T&E I would not think this JB has been put in recently so the reference to "these days" is probably not appropriate.
This just reminded me I have a couple boxes of old 20a and 30am round JBs I still need to use up before buying a nother load of Wago boxes
Take them to the local clay pigeon shoot.
Should I take out the RCBO's and replace with re-wirable fuse's. 😜
The comment was referring to someone's suggestion of replacing the OP's existing JB with a J601 screw terminal one rather than a wago type. He wasn't referring to the original junction box.
Whats wrong with screw terminals, they have been around for decades.
Just for info I was altering some wiring last year for a friend, wagos in the back of a switch for the N not much slack so instead of cutting the wago off (push in type) I pulled the conductor out and it didnt take much to pull out, just thought id share that.
And MCB and main switch terminals also are screw type.
Reactions: 7029 dave
I've nothing against them, it's more to do with ease and also being maintenance free.
They are only MF if used with the enclosure
Is this JB adequate for the design and use.
Shaun H,
Petej999,
