Discuss Is this JB adequate for the design and use. in the UK Electrical Forum area at ElectriciansForums.net
I found this JB in the loft, the mice have eaten the JB cover as well as some of the wiring, but aside all that in your opinion do you think the JB is overloaded?
We can't say if it's electrically overloaded, but at least one terminal is mechanically overloaded.
Irrelevant, since the fixing point for the cover is totally broken off, and it needs replacing ASAP by a more modern junction box, suitable for the number of cables present, such as a Wago box and connectors.
Hmm continental 7 on the bottom right grey cable with a double cross through it, wonder if that is indicative of the installers origin.
Yeah some ham fisted sparks added a cable and couldn't get the lid on properly so just mashed it up and chucked it most likely
Are there any earths on any of the circuits? But if this a spark asking the question back to college for you
We have power in and power out complete with earth wires, plus the switch and lamp wires for two lights, all without cpcs, and then the orange flex feeding a second lamp on one of the circuits.
All, except the flex, pre 1970.
To be fair it is old twin cable with no cpc so in reality I would be looking at a re-wire sooner than later
As most of the cables are Red & Black T&E I would not think this JB has been put in recently so the reference to "these days" is probably not appropriate.
This just reminded me I have a couple boxes of old 20a and 30am round JBs I still need to use up before buying a nother load of Wago boxes
Should I take out the RCBO's and replace with re-wirable fuse's. 😜
The comment was referring to someone's suggestion of replacing the OP's existing JB with a J601 screw terminal one rather than a wago type. He wasn't referring to the original junction box.
I can't think why someone would use a screw terminal JB these days, when it's far quicker to wago type and make it maintenance free, whether needed to be or not.
Whats wrong with screw terminals, they have been around for decades.
Just for info I was altering some wiring last year for a friend, wagos in the back of a switch for the N not much slack so instead of cutting the wago off (push in type) I pulled the conductor out and it didnt take much to pull out, just thought id share that.
And MCB and main switch terminals also are screw type.
I've nothing against them, it's more to do with ease and also being maintenance free.
Why would you cut it off when you can just remove the conductors from it?
A pull with a bit of a twist is the method for removing the conductors.
What are you actually trying to get at here?
I don't see what the difference is, if using another make of box. I use Wiska boxes with them and can't see a problem.
My question was in using them without an enclosure at all.
Also, I think the enclosure would have to be stamped MF if used as BS 5733 Maintenance Free box.
Reply to Is this JB adequate for the design and use. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
So a brief foray into domestic has me slightly bemused…. Neutrals at switches. Easy enough if you’re wiring loop at switch, but if you have...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
