- Reaction score
- 6,401
So a brief foray into domestic has me slightly bemused…. Neutrals at switches. Easy enough if you’re wiring loop at switch, but if you have good reason to loop at light then logically all you need do is drop 6243 as your switch cable, simples. Except…. What about on a 2way / int run where you’re ONLY dropping the 3c to each switch and picking up the S/L in a JB elsewhere…. What do you do then?!
