because the 32A MCB is protecting the cable that feeds several sockets.
You just had to answer .....................
More to the point why do you have a 100amp switch and a 60amp main fuse ,eh tell me that
So the accesories have nothing to do with it as long as we protect the cable in question. i had a lighting circuit the other day on 16 amp (normally bells starts to ring)Ref Method E Checkrd RegsMCB ok someone validated my cert. told me that should of failed because the light switch was only rated at 10amps
16A is max allowed on lighting ciruit so is ok providing ...............
