- Aug 12, 2017
- 14,313
- 20,712
- 3,557,381
- 51
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here?
The green wire is bonded to the metal mainswitch and the installation is metal conduit.
I don’t know if the bare wire is an incoming earth off the cable, going out to a rod or linked to the lightning conductors.
It was just having a removable cut out like this which means very easy to disconnect and leave something not earthed/bonded.
It’s not even sealed.
Or is it just a type of connection block I’ve not seen before
