Discuss kitchen isolator requirements in the Industrial Electricians' Talk area at ElectriciansForums.net
M
mark7600
Hi I am 1st fixing a kitchen rewire, My boss is away for a couple of days and left it for me to finish. There is a hob , hob extracor, oven, microwave, dishwasher and washing machine. Apart from the hob and oven which other items need to have an isolator? The client wants the minimum and them to be hidden away from view. I know that the oven/hob has to be within 2m and easily accesable. Is this the case for all isolators?
I would really appreciate some help as I would like to finish it asap.
apart from the oven the others will just be on soecket outlets and dont need sperate isolators
somepeople put switches above the worktops to control sockets below, that is not a requirement
Thank you guys for the help, The Grid sounds like an excellent solution. Yes wayne I am thinking more of a bonus!!! Maybe a nice new dewault! But will probably have to put up with a few 5.5 bits and raw plugs and pat on head.
why dont you fit a grid switch then you can isolate them all from the same position,all in one tidy unit job done.
I presume you mean multiple grid switches at one grid point? Not all of the appliances running off a single grid switch?
And aynway, if the client doesnt want it, and it is not a requirement, why put one in anyway?
Yes I was thinking of that, But I think i will just put two in for the oven and hob. The others I will just put skts behind units from the kitchen ring. The extractor is connected to the ceiling so not sure about that? maybe iso next to hob one and put cable up capped behind wall and above ceiling to grab when kitchen fitters put it in? AS long as it is safe and what the clients wants I just need to finish tommorrow. can i put iso in cupboards?
Yes Shakey I Did Mean A Grid Arrangement With Each Item Of Equipment On Its Own Switch/fuse Just Thought That Bit Went Without Saying.
Sorry Paul, sometimes you need to spell things out for me
I'm not a proper sparks you see:p
And i aint had Bane to pull my strings for awhile ;)
Reply to kitchen isolator requirements in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
