Discuss Klik rose wiring, lights, emergency lights and pir's in the UK Electrical Forum area at ElectriciansForums.net
Hello I'm a first year apprentice and I'm struggling to get to grips with these klik rose wiring. Can someone please explain how you would wire these up from start to finish, what colour wires go to what terminals, how to wire the lights up with emergencies and pir's ? Thanks
klik wiring diagrams - Bing images - https://www.bing.com/images/search?q=klik+wiring+diagrams&qpvt=klik+wiring+diagrams&qpvt=klik+wiring+diagrams&qpvt=klik+wiring+diagrams&FORM=IGRE
Google is your friend, simple really if you can be bothered to look
So you'd run LNE from board to klik ax, then klik plug to pir would be 4 pin LNEA so that would be 4 core, then from the pir to the light use 4 core which has terminals L1 as S/L L2 perm and N and E would that be right ? But I have also seen 3 klik roses being used for a pir and em and something else but weren't sure what it was for, how would you link all them together ?
Reply to Klik rose wiring, lights, emergency lights and pir's in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
