OrangeBillsFan
- Reaction score
- 0
I am installing recessed LED lights wired in series. My question is, the last light in the series will not have a ground to connect to...what is the solution?
Discuss LED Lights wired in series in the UK Electrical Forum area at ElectriciansForums.net
It depends on the LEDs. Some are wired in series, some in parallel.Why on earth would you wire them in series? If one fails they all go out, and trying to find which one failed is time consuming.
Wire them in parallel as standard practice.
Reply to LED Lights wired in series in the UK Electrical Forum area at ElectriciansForums.net
