Discuss LED Power Rating on information on my 12v lamp in the UK Electrical Forum area at ElectriciansForums.net
EddieB
On the LED lamp I have I have the following information, 12v-440mA-3.4W, these figures don't stack up according to Ohms Law, I'm not too familiar with load ratings and calcs regarding LED's
The LED chip itself may be 3.4W but the power used from the circuit is higher due to the loss in the ballast resistors. Same as with fluorescents and discharge lamps, where e.g. a 36W fitting takes a 36W tube but uses more than 36W from the mains due to loss in the control gear.
BTW ohn's law is about resistance not power.
Thank you for your reply, it makes sense but your statement about ohms law confuses me, power, voltage, resistance and current can all be obtained with any two readings .. 🤔👍
Yes, but ohm's law only states that the current through a conductor is proportional to the voltage across it (for most materials.) Ohm's law doesn't apply to LEDs since they are semiconductors and do not have a linear relationship between current and voltage. But the power is still voltage multiplied by current, as that relationship doesn't depend on ohm's law.
Thanks for clearing that one up 😀👍
Reply to LED Power Rating on information on my 12v lamp in the UK Electrical Forum area at ElectriciansForums.net
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi everyone. I should start by saying I'm not sure I'm in the right place here (this isn't a householder issue - I'm making a Ghostbusters...
Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice. The (very old) 230VAC to 13.8VDC power supply broke down...
