Discuss Light switch wiring help in the Lighting Forum area at ElectriciansForums.net
Anne76
Hi can anyone help me with this light switch? Photos of how it was wired to old switch but new switch is different with different names.
I’m confused to where the wires go?
Attached some photos
i cant quite see the markings on the old switch.... but its made up of triangles of terminals...
The first has a single terminal at the top, 2 on the bottom.... the second switch has the single at the bottom and the 2 at the top. the third is same as the first..... Are the terminals marked C, L1,L2? it may be L1,L2,L3..
Doesnt really matter, as long as you know the single one at the pointy end of the triangle is the common, and the switch basically switches between L1 and L2.
Now for the new switch... it appears the markings are Com1, L11,L12 for switch 1....... Com2,L21,L22 for switch 2 and Com3,L31,L32 for switch 3
You can see they are not in the traditional triangle shape... but i have denoted in bold which terminals belong which switch
Reply to Light switch wiring help in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
hi could some one please help me with the wires on this light switch please i need to change it to a new one any help would be apreciated thanks
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
