Discuss Lighting automation in the Lighting Forum area at ElectriciansForums.net
ses
Evening all
Just purchased a flat over here in west london and looking to install some lighting control
Im going to have 6 zones in two different rooms
Room 1 needs 2 points of switching as two doors
Room 2 needs 3 points of switching as 1 door plus switch either side of bed
It would be great to be able to switch each zone on and off plus be able to use 4 preset scenes from each switch
I would ideally like to have one faceplate at each switch point rather than multiple
Ive looked at and emailed Lutron, Hamilton as I have some knowledge of there product but if anyone else has any ideas or products that would facilitate this please divulge
Loxone, Rako, Crestron, Legrand etc all seem very complex for this install
I know with Lutron you can have the master all on and all off plus 4 scenes but can you have each zone individually all on and off as well as the scenes
Have a look at LightwaveRF, it's designed to be retrofit and setup by 'non specialists' however some wiring can be required depending how advanced you go. It will do all you have discribed plus enables you to control via mobile phone.
Reply to Lighting automation in the Lighting Forum area at ElectriciansForums.net
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
