Discuss Lighting switches to smart.. in the DIY Electrical Advice area at ElectriciansForums.net
Mjpuds
Ok after pulling two switches off the wall in my lounge I have come to the conclusion I might be able to remove one of them.. I have one two gang and one old dimmer .. wanting to either replace 2 gang with a smart 2 gang . Or replace dimmer with singal smart . Looking at the switches I have the dimmer without a neutral .. and the present two gang could control both by using Alexa. Or is there a way the the dimmer switch (red,blue,yellow) be made to have a neutral coming from the two gang that does have a neutral.. the red blue yellow wires link back the the dimmer switch.
I don’t think the black wire there is a neutral tbh. It’s a switched live to another light.
LightwaveRF doesnt need a neutral as suggested.
Thanks for the reply. I have already purchased a few wifi switches and installed them already . So it would be nice to keep the same design.
Sadly these do need a neutral.
Looking at the set up there, it’s possible to get a neutral IF it’s a central joint box system. One of those cores could be used. You won’t need a 2 way switch if you’re replacing with smart.
I would advise you seek an electricians help with this, and be prepared to lift upstairs carpet or flooring to reach the JB.
Ok I have a picture of the unit I was hoping to use . Strangely when connected the second light fitting flashes like a strobe.
If I were to blank off the second switch where the very old dimmer what should i do with these to either finish off the cables or join them to complete the circuit .
Reply to Lighting switches to smart.. in the DIY Electrical Advice area at ElectriciansForums.net
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
