P
Piratepete
Hi Guys
I'm working in a house which has 2 consumer units. One supplying the original house is by the DNO's cutout and meter through Henley blocks. Installation is TN-C-S.
The other is some way away and supplies an extension. It is fed with a 10 sqmm T &E from a 45 amp DP switch fuse by and connected to the same Henley blocks.
IMO the 4 sqmm earth in the T&E is inadequate and it should be 10 sqmm.
Assuming I'm correct, it will be a challenge to route a 10 sqmm earth all the way through the house or even around the house from CU to the MET.
A simple solution would be to make this part of the house TT (the outside wall is only 2 metres away).
Would this be permitted?
Note: Gas and water bonds currently are only connected to the original CU.
