Discuss Main switch in the UK Electrical Forum area at ElectriciansForums.net
537.2.1.1 could te;ll me im wrong[/QUOTE
that's more applicable to individual circuits rarther than the whole installation. look atr 537.2.2.1. both L and N conductors are "live".
ok im happy to go with 537.1.4, so would you code this a c3 as must of been fine when installed 19 yrs ago
What exactly was fine 19 years ago?
And an inspection is not about whether something was allowed in the past or not.
Well u can't say it's a c1 and c2 if it was acceptable when installed
Yes you can, otherwise you will be passing dangerous installations as satisfactory!
An EICR is an assessment of the safety of an installation for continued use which uses the current version of bs7671 as the standard of safety against which the installation is judged.
If an item is immediately dangerous then it is coded C1, if an item is potentially dangerous it is coded C2 both irrespective of whether it complied at the time of installation or not.
Safety improvements which could be made are recommended via the C3 code, this often relates to items which complied with previous regulations but improvements are now possible.
It is not a report on absolute compliance with the current regulations which is why it must not be used to certify new work.
Fused neutrals, bare conductors in wooden trunking, open fronted switchgear, bare busbars insulated by paint only, live parts accessible without the use of a key or tool were all permitted once upon a time, but all get coded.
Reply to Main switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, if I cannot access the line side of a crabtree 100A DP main switch. Would someone enlighten me how to conduct safe isolation on this...
Good evening, I wondered how the MCB between RCD and the Main switch is wired while watching this video. Photo attached. I assume a busbar link is...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
