Discuss Mains supply to flats in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys could really do with some advice on this one. I've been asked to quote to put a new landlord supply into a block of flats. At present there is one board feeding three individual blocks all attached with lights and one socket in each. I've quoted like for like but someone at Electricity northwest has said its regulation to have a meter and board for each Block. Not a regulation I've ever come across. Are they right or just trying to get extra meters in for the standing charges
Can you explain the setup a bit more please?
Does each block have its own incoming supply from the DNO?
How are the landlords final circuits installed between blocks?
How is the distribution to each flat installed?
If each block has a seperate feed from the DNO then there shouldn't circuits running between each block unless the earthing systems have beeninked according to DNO spec and with their permission.
From a BS7671 point of view it is very dodgy in my opinion, but I'd want full details before making a decision.
At the moment for the landlord supplies it has one board feeding all three blocks. Old council flats all conduit to one place. Utility company have put new feeds in to all the flats and are saying we need a landlord meter and board in each Block
Forgot to say the DNO have in there wisdom already put new feeds in to each Block and just said we need to get meters installed. It was and has been since it was built just on one supply
Reply to Mains supply to flats in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
