Discuss maintaince free junction box in the Electrical Tools and Products area at ElectriciansForums.net
I exhaust all other avenues before putting maintenance free (MF) junction boxes under floorboards as, put simply, it's never going to be as good as a continuous length of cable. However, sometimes you have to.
I use wagobox http://www.wago.ltd.uk/enclosures/wagobox/ (not wagobox light as these are not MF). Plus they require a cable tie around them in the given slot to be deemed MF. Also they must only be used with correct wago terminals for the given box.
@diyterry give us a little more background of what your looking to acheive and we may be able to sujest other methods, possibly, just noticed your in Suffolk too, so if you do get in a tangle give me a pm
In the past someone has connected a lighting circuit to the ring main via a switched and fused surface mounted box, this is now obsolete, so I'd like to remove it to tidy the wall up.
Reply to maintaince free junction box in the Electrical Tools and Products area at ElectriciansForums.net
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi all, with majority of new builds adopting loop at the switch for residential lighting circuits these days, am wondering if any one still...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi Everyone, Sorry in advance if this is a silly question. There is a junction box in my mother's kitchen, on the wall above her kitchen...
