Discuss My experience of the AM2 taken at Birmingham in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I’d practice doing both methods (global and individual) and do the one you feel most comfortable with as on the day you need to show that you’re confident. So I disconnected the carbon, luminaire, rcbo (neutral and earth fly leads) and ensured that the spur was off for the heating system. The carbon and luminaire they give you push in connectors so easy to just pull out for testing purposes. For the motor, I tested up to the DOL (top of contactor) and then from the bottom of the contactor to the motor. They don’t give you a motor just a blank box with points to test on so no worries there.
I’m happy to do either IR test, I know the procedures for each test, it’s just I wasn’t sure what to disconnect during this process and particularly the motor circuit. That is very helpful, thank you Adam.
You know with over 35 years of experience in this trade I think I'd struggle to do that lot properly in eight and a half hours !
I think you youngsters have done extremely well to complete this successfully, it's encouraging that there will still be some good Sparks out there in the future. :)
The eight and a half hours is only for the install, if you didn’t know? Without trying to sound patronising. It doesn’t sound that long but it’s not a big board, so hopefully I should be okay for time.
I believe you get around 3 hours for testing the installation and 2 hours for fault finding.
Ah that's not so bad, I thought all of the above had to be done in that timescale ! In my day [which is far more recent than one or two on here :D] the different types of installation work were done throughout the course over a period of time and assessed individually, I'm sure with preparation you can sail through the AM2 but it does seem a bit daunting initially.
Reply to My experience of the AM2 taken at Birmingham in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Finished my AM2 the other day, pretty confident with most of it except the testing. When I done my live polarity, Ze and PFC tests for some odd...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Electrical Courses
