Discuss new timer switch in the UK Electrical Forum area at ElectriciansForums.net
PaulB54
Hi
I have 3 light switches in a single box. 1 switch controls the hallway lights, the 2nd switch controls the garage inside lights and the 3rd switch controls the outside lights.
I would like to replace the outside light switch with a timer switch.
The switch I will take out has 2 black wires and a ground wire. The timer has a white, a black and a blue wire. I am assuming the blue and black will replace the 2 black wires on the original switch, but I don't know what to do with the white wire.
All the white wires are connected together. I am assuming that one of the black wires go to the light and the other to the bundle of black wires. Any one can tell me which wire goes to which?
thanks
Paul
Hi
thanks
Paul
Paul the timer switch wires like it shows the black is your hot and the white is the neutral and when your timer comes on it will make the blue hot for your light outside
[automerge]1567555177[/automerge]
Hi
thanks
Paul
It’s just a 120vac timer from the picture on the timer and with the white and black it powers up the timer. Do you know the voltage on the light outside
[automerge]1567555594[/automerge]
Hi
thanks
Paul
Paul the black on top in the wire nuts goes to where the switch is showing the you have to get one of the whites and hook it like your print on switch The bottom black goes with the blue wire
Thank you-
So the old switch did not require to go to the neutral? But the new one will.
So I am guessing the blue and black on the new switch will go to where the 2 black wires on the old switch were and I will have to add a wire from the white bundle to the white switch wire. That right?
Thank you-
That’s correct just do it like I told you black on top goes to the bottom of the switch then the other black to the blue
Reply to new timer switch in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
