Discuss New Wylex “miniature” dp rcbo in the UK Electrical Forum area at ElectriciansForums.net
polo1
Are these actually in any wholesalers now, what price and has anyone fitted them? (Other reduced size dp rcbos are available too, allegedly).
Same as the small sized hager rcbos, they are out there but hard to get hold of, i am told you can have them ordered in and will still save off the hager RRP. Which as we all know is an absurd amount for most things. if you have the product code google it and have a look.
It's worth mentioning that as well as for Wylex boards, Electrium are also bringing out miniature/no functional earth lead/switched neutral RCBOs for Crabtree Starbreaker boards, too. Current link (may change with time): Crabtree - https://www.electrium.co.uk/products/crabtree
Link to PDF.
Looking forward to seeing these released into the wild and generally available.
Are the Hager ones not two modules wide?
I think all the single pole + switched neutral RCBOs are two modules wide, I have been looking at the Hager ones recently (link below).
Technical Properties ADA906U - http://www.hager.co.uk/product-catalogue/energy-distribution/protection-devices/rcbos/rcbo-single-pole-switched-neutral/ada906u/46670.htm
For unknown reasons these are quite scarce and rather expensive - a single pole Hager RCBO has a list price of £88 and a wholesaler price around £20, whereas the SPSN list price is £130 and wholesaler price around £100.
Does anyone else expect SPSN RCBOs to become increasingly in demand? ...as a single pole full RCBO board offers discrimination but at the sacrifice of disconnecting the neutral, unless there's also an upstream timed delayed RCD, but that cancels out the discrimination you've installed the RCBO board for in the first place.
SBS compact RCBO's are switched neutral, single module and about the £15 mark.
SBS Trade Sales - Products - https://www.sbstradesales.co.uk/products/
We should of been using double pole or switched neutral rcbo's and double pole mcbs if a group of circuits are protected by an rcd from day one imho, not being able to reset an rcd because of a neutral earth fault on one circuit is a royal pain in the neck. And Europe have been using them for years, I thought we were harmonised with them as well. :confused:
Reply to New Wylex “miniature” dp rcbo in the UK Electrical Forum area at ElectriciansForums.net
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Customer has a Wylex NS11 board with NSC cartridge fuses. They want some work doing, so now need RCD protection. The NHXB RCBO have always been a...
Last week I took the opportunity of having the mains power off to test the RCBOs in a Wylex Consumer Unit, fitted nearly 5 years ago, which has...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
